Can Premiere import Panasonic’s AVC-Intra 100 codec?
I need to quote a Premiere edit project before having access to test that video files will import natively. Can someone give me advice on whether 1080p files from Panasonic AJ-HPX3100 cameras will import natively into Premiere Pro 22.5 on an iMac? If not, is there a transcode workflow to recommend? Thank you.
