Activity Forums Adobe Premiere Pro Can Premiere and Final Cut share 1080i files?
  • Can Premiere and Final Cut share 1080i files?
    Posted by Chris Varner on May 20, 2009 at 4:30 pm
    Captured 1080i files in Premiere. Trying to share them with an FCP editor. FCP won’t play them. Is this even possible and is there anything the FCP guy can do to use my files?
    David Dobson replied 17 years, 3 months ago 3 Members · 5 Replies
  • David Dobson
    May 20, 2009 at 11:21 pm
    What kind of 1080i file? HDV? AVCHD? DVCPROHD? Is it a Quicktime file or an AVI files or m2t file or an mfx files……..
  • Chris Varner
    May 21, 2009 at 12:59 pm
    HDV. mpegs. Apparently FCP can’t edit mpegs. Sweet.
  • Dennis Radeke
    May 22, 2009 at 1:23 pm
    FCP likes Quicktime and just about nothing else. If the HDV files were captured as Apple QT via FCP, then Premiere Pro could read it, but not the other way around. If you really need to interact with FCP for this project but can’t recapture, you could use the adobe media encoder to create Apple compatible files (maybe DV100) and then create a Premiere Pro preset that will also read them.
  • David Dobson
    May 22, 2009 at 1:42 pm
    I should amend that – PPeo on a PC can not see Apple QT HDV. On a MAc I guess it would – but then on a Mac you’d have captured it as a QT HDV anyway.
  • David Dobson
    May 22, 2009 at 1:48 pm
    PPro CAN NOT see Apple QT HDV files.
