Activity Forums Maxon Cinema 4D can particles be assigned to an object buffer?
  • can particles be assigned to an object buffer?
    Posted by Alan Flood on January 25, 2011 at 9:18 pm
    Hey everyone,
    I’m currently working on a scene where I’m using pyrocluster particles to simulate airflow. The way I have things set up is that I have some basic emitters and I give them the pyrocluster material – which is basically just a colored spherical particle. I’m looking to assign the emitted particles to an object buffer so I can give them a glow later in AE but it doesn’t seem to be working. Does anyone know if this can be done via some other means?
    Alan Flood replied 15 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 25, 2011 at 9:39 pm
    If you’re not using any other atmospheric effects you can render an atmosphere multipass layer that will just contain the PC effect on a black background.
  • Alan Flood
    January 25, 2011 at 9:46 pm
    Excellent Adam – thank you very much. Perfect!!!
