Activity › Forums › Adobe After Effects › Can not render file larger than 4GB
  • Can not render file larger than 4GB
    Posted by Gasdrawn on November 13, 2006 at 3:51 pm
    hi
    I can’t render file bigger than 4GB
    For example
    i was rendering out this project the other day and every time the file size increases pass 4GB the program prompt me with a error message
    something along the line of “Bad I/O…..”
    can someone tell me whether this is normal or not
    AE7
    Window Xp sp2
    2.5G Ram
    Gasdrawn replied 19 years, 10 months ago 2 Members · 2 Replies
  • Michael Duff
    November 13, 2006 at 9:09 pm
    I’m guessing your drive is formatted fat32….. you can find out by going to my computer and right clicking on the hard drive and going to properties…. fat32 file systems have a file size limit of 4Gb plus if you are rendering to AVI I think they also cap at 4Gb…. I’d suggest you reformat at least one of your drives to NTFS – it’s a much better file system when working with large volumes and large files….
    alternately you could try rendering out an image sequence (such as TARGA), this way there will be not be one single file…
    you can also find out more info by searching google or the COW archives for “FAT32” or “4Gb limit”
    hope this helps you
  • Gasdrawn
    November 14, 2006 at 10:55 am
    thanks
