Activity › Forums › Apple Final Cut Pro Legacy › Can no longer set Default transition
  • Can no longer set Default transition
    Posted by Leonard Frankford on January 8, 2010 at 12:43 am
    I used to be able to select an edit point and hit command/T to apply a dissolve, my default transition. Now, command/T does nothing. I see in the Effect menu that Default and Set Default are grayed out and cannot be selected. How do I reactivate my default settings? Thanks.
    Leonard F.
    Rafael Amador replied 16 years, 8 months ago 2 Members · 3 Replies
