Activity › Forums › Apple Final Cut Pro Legacy › Can no longer output DV AVIs with proper resolution
  • Can no longer output DV AVIs with proper resolution
    Posted by Jonathan Capra on September 17, 2009 at 10:54 pm
    I remember that, until some time ago, I was able to output DV-encoded NTSC AVI files from Final Cut Pro using the Quicktime Conversion Export feature. As I recall if I was outputting from a sequence that was 720×486, it would chop off the top and bottom 3 lines and change to the correct aspect.
    As of late, I notice that the resulting files are now somehow botched. AVIs exported from a 720×486 sequence still end up having 486 lines (which i didn’t even think the codec allowed)… and when I reimport a resulting AVI into FCP, I see some combination of horizontal interlace/aspect errors and destructive cropping on the right side. Performing an Analyze Movie on the clip lists it as being 640×480 or 640×486 rather than 720. However I have brought the same files into Windows-based NLE’s like Vegas and those NLE’s interpret them as being 720 and they display fine.
    I tried many different combinations of outputting (non-custom) Quicktime-via-FCP, Quicktime-Conversion-via-FCP, Compressor and Quicktime-Pro-Player-Export… But the only way I can manage to get a proper 720×480 DV-encoded NTSC AVI file is for me to first export a (non-custom) Quicktime in FCP, choose ‘DV NTSC 48khz’ from the drop-down, then open the resulting .MOV file in Quicktime Pro Player and then use the Export feature to export an AVI with the ‘DV/DVCPRO – NTSC’ feature.
    Does anyone have an idea how this changed on me? My only thought is some Quicktime or FCP update in the recent past, messed up this particular feature.
    Jonathan Capra replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
