Activity Forums Adobe Premiere Pro Can new PP CC create a bin of found clips by using the search function?
  • Can new PP CC create a bin of found clips by using the search function?
    Posted by Reed Brown on July 14, 2014 at 10:18 pm
    When using criteria bin search function, can the newest PP CC now create a new bin of clips based on that search? Like FCP 7 is (was) able to do…search, find clips, add clips to new bin selected, all found clips now in a new bin! Thanks.
    Kevin Monahan replied 12 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    July 15, 2014 at 7:43 pm
    Hi Reed,
    Yes. In the search box, type the search term in the Find box, for example: IMG_462. Premiere Pro finds all the clips with that prefix. Create a new bin, then drag the clips into it.
    Does that help?
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Reed Brown
    July 15, 2014 at 8:22 pm
    Yep, that’s what I was looking for. Seems a bit clunky as you type in letters, but it does the job. I noticed with fewer columns open and set to “visible”, it takes less time. I’m upgrading to the new 2013 MacPro so the searches should go much, much faster. Thanks for the advice.
  • Kevin Monahan
    July 15, 2014 at 11:27 pm
    Hi Reed,
    If you are running CC 2014, the search in “Find” has been sped up dramatically. Please update if you have not already.
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
  • Reed Brown
    July 16, 2014 at 12:18 am
    Absolutely! My new MacPro is in delivery. Yeah!
  • Benjamin Reichman
    July 16, 2014 at 5:59 pm
    Yes, the search function before CC 2014 was so slow as to be utterly unusable. (It would take up to 60 seconds–literally–after I typed a short word like “house” or “Sierra Leone” for the letters to simply appear in the box, and for the search to complete would take even longer sometimes.)
    But now search actually works! One of my favorite fixes in CC 2014.
  • Reed Brown
    July 16, 2014 at 6:28 pm
    Excellent to hear and can’t wait to try it out. This vastly changes the way I log clips.
  • Kevin Monahan
    July 19, 2014 at 2:13 am
    Cool, glad you like!
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
