Activity Forums Avid Media Composer Can MC 5.5 open a media composer 6 project?
  • Can MC 5.5 open a media composer 6 project?
    Posted by Andy Field on December 17, 2011 at 2:55 pm
    Need to deliver finished timelines to a post-house that’s still on 5.5 — is it possible to to a SAVE AS 5.5 out of version 6 – or can 5.5 read a 6 project? If not are there other options like XML out? Thanks
    Philippe Ralet replied 14 years, 9 months ago 5 Members · 6 Replies
  • Michael Hancock
    December 17, 2011 at 3:07 pm
    The project should transfer fine. I don’t believe the Pan and Zoom plugin is backwards compatible though so if you used it the moves will have to be recreated.
    Michael Hancock
    Editor
  • Andy Field
    December 17, 2011 at 3:53 pm
    Great – has anyone actually tried this backward compatibility? I’m downloading a trial of 6 and will report if it actually works – Thanks
    Andy Field
    FieldVision Productions
    N. Bethesda, Maryland 20852
  • John Pale
    December 17, 2011 at 10:18 pm
    Works fine. Done it several times already
  • Mike Most
    December 18, 2011 at 6:11 pm
    Repeat 3 times:
    I am not on Final Cut anymore.
    Then rejoice that you’re using software produced by a company that actually understands the editing business and doesn’t ignore things like backwards compatibility.
  • John Pale
    December 19, 2011 at 1:45 pm
    “Then rejoice that you’re using software produced by a company that actually understands the editing business and doesn’t ignore things like backwards compatibility.”
    Mostly true…however Avid made a change to the DNX codec several years ago (around MC 4?)to meet SMPTE spec that causes some tricky issues with backwards compatibility.
    Generally no problem with bins and projects, though. Way better than FCP.
  • Philippe Ralet
    December 27, 2011 at 2:52 pm
    Hi have upgraded in past two weeks, have sent bins with sequences , including alpha channels, mattes keys, but no major effects. All is good, no problem whatsoever …. he says cautiously
    Let’s get this done and go outside and play !!!
