Activity Forums DaVinci Resolve Can mac see full GPU RAM of 4GB non flashed PC card? – Will it still run slower than flashed?
  • Can mac see full GPU RAM of 4GB non flashed PC card? – Will it still run slower than flashed?
    Posted by Robert Ruffo on February 18, 2014 at 8:09 pm
    I hear all kinds of contradictions. Wondering if some of the learned folks here have drawn any conclusions.
    MacVidCards has smaller selection, and higher cost than going PC route – but at least you know it will work.
    I have heard that non flashed cards do not use full 16 X mode, so are much slower. Still true? 4GB card will work at full RAM or not?
    Robert Ruffo replied 12 years, 6 months ago 4 Members · 4 Replies
  • Juan Salvo
    February 19, 2014 at 4:34 am
    Deja vu, dude!
    I’ve not seen non-flashed cards running at half speed, and I’ve run lots of non-flashed cards. CUDA has direct memory access and isn’t limited by driver issues related to OpenGL or OpenCL.
    https://JuanSalvo.com
    https://theColourSpace.com
  • Sascha Haber
    February 19, 2014 at 9:46 am
    They perform exactly the same..
    They just don’t boot…thats it
    A slice of color…
    Resolve 10.1.0.021
    Colorist / VFX / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Ericbowen
    February 19, 2014 at 3:37 pm
    The comments you see are likely related to the PCI-E Gen 3. The Mac Pro’s don’t have PCI-E gen 3 slots which the newer cards use. I wouldn’t worry about that though because the current GPU acceleration is not normally pushing a PCI-E Gen 2 16 X slot.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Robert Ruffo
    February 19, 2014 at 5:51 pm
    The final answer talking to the head of tech of a large post house down the block) is: Yes and No
    Yes a PC card will run at full speed in OSX, but on the PC side (in Bootcamp) it will still act like a PCI 1.0 connection even in a 16X slot. In an older 2008 Mac Pro, a PC card will run in 1.0 mode under both OSs (not confirmed, as they have no more 2008s to check – but probably/rumor has it)
    MacVidcards flashed cards also ensure that power draw is never dangerous, and that heat is reasonable for a Pro enclosure, which is more of a long term issue than short (he said they’ve had Pro burn-outs longer term with PC cards, and none with MacVidCards, but they may have really pushed the power thing too far – hard to say). Mac Vid Cards does limit power usage inside the card for cards certified to work without a PSU. Apparently, also, stability is just a bit better.
    For me, I think it’s better to have peace of mind than risk my expensive tower, and I use the PC side a lot wfor Pc-only software, so an extra $200 was not a very big issue. I tend to like the “cry-once” buying philosophy whenever possible, but that’s just me.
