Activity › Forums › Adobe After Effects › Can light in a precomp affect 3D objects in the main comp?
  • Can light in a precomp affect 3D objects in the main comp?
    Posted by Levi Lenaerts on June 12, 2009 at 9:47 pm
    Hi there,
    i have a precomp, which sits in a main comp. In the precomp, i have used some lights.
    When i switch over to the main comp, i set the collapse transformation checkbox on, and yes, i see the lights working on objects of the precomp.
    Problem is, those lights (which sit in the precomp) do not affect other 3D objects in the main comp? (like for example a simple background solid which is switched to 3D in the main comp)
    Am i doing something wrong here, or is this just not possible?
    Thanks in advance!
    Levi
    Jack Chute replied 15 years, 3 months ago 3 Members · 3 Replies
  • Andy George
    June 14, 2009 at 5:02 pm
    Hi Levi,
    Short answer – No
    When you hit the collapse transformations button you are actually telling AE
    to ignore the lights and camera in your pre-composition and expose the 3D attributes of
    the precomposed layers to your main compositions camera and lights.
    So you should not be seeing your pre-compostions lights affect Anything
    in your main composition including the precomposed layers.
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7ed6a.html
    -Andy
  • Levi Lenaerts
    June 15, 2009 at 9:59 am
    Hi Andy,
    thank you so much!
    Have a nice week!
    cheers,
    Levi
  • Jack Chute
    July 1, 2011 at 2:56 pm
    So there isn’t anyway to get a light from a precomp to function in a main comp and interact with other 3d objects?
    I’m trying to make a top-down view of a car with head lights interact with other cars with head lights. In short, I was planning on making one precomp with the base car with its lights attached and then comping numerous of these complete cars together so that I can move them around and have the pre-attached head lights illuminate each other.
    Is this possible?
