Activity › Forums › AJA Video Systems › Can Kona cards capture Dolby E?
  • Can Kona cards capture Dolby E?
    Posted by Ben Cheng on September 6, 2006 at 4:19 pm
    Hi All,
    I would like to find out if anyone has any experience working with HDCAM tapes with Dolby E surround audio?
    These tapes are typically broadcast master, meant for tranmission.
    There’s a need to capture & edit the material on these HDCAM tapes & the 5.1 surround audio tracks are in Dolby E data stream.
    1 possibility is to decode the Dolby E into 5.1 discreet audio tracks & capture via AES/EBU.
    I’m curious if its possible to keep the metadata of the surround mix in this way.
    The workflow is to keep the editing process to the final delivery tapeless & go file-based.
    The final distribution surround format is Dolby Digital.
    I’m also looking for software to either:
    – convert the Dolby E to Digital
    – discreet audio tracks + metadata into Dolby Digital
    Any advice is greatly appreciated.
    Cheers,
    Ben Cheng
    The Media Village
    Singapore
    Ben Cheng replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
