Activity › Forums › AJA Video Systems › Can IO add 2:3 pulldown to a 23.98 sequence?
  • Can IO add 2:3 pulldown to a 23.98 sequence?
    Posted by Guy on October 24, 2005 at 5:52 am
    With the latest firmware and drivers IO doesn’t seem like it can add 2:3 pulldown when playing back a 23.98 sequence. When I change the sequence pulldown pattern to 2:3 it gives me a 2:2:2:4 pattern on output. Does the IO support 2:3 pulldown?
    Aaron Neitz replied 20 years, 11 months ago 2 Members · 1 Reply
  • Aaron Neitz
    October 28, 2005 at 6:48 pm
    The Io doesn’t do the pulldown, it’s handled in software by FCP. It will automatically add 3:2 when you play a 23.98 sequence with the Io connected. Go into System Settings -> Playback Control -> and set your pulldown pattern to 2:3:3:2 for a regular 3:2 setting.
