Activity Forums Apple OS X Can idvd burn to another external burner???
  • Can idvd burn to another external burner???
    Posted by Mark Chadwick on January 10, 2006 at 6:33 pm
    Hello,
    It doesn’t look like I can but I thought i’d ask. I have a Lacie external dvd burner and I was wondering if there was a way to make idvd burn to the lacie instead of the internal burner. I know in toast you can change to which burner you wanted but can you do that in idvd??
    thanks
    mark
    Craig Alan replied 20 years, 8 months ago 3 Members · 2 Replies
  • Tony! Hulette
    January 11, 2006 at 3:11 am
    Officially, no it won’t work. You need an internal SuperDrive to burn DVD’s from iDVD. However, there is a workaround. You can save your DVD project as a Disk Image (File > Save As Disk Image). You can then burn the image to a DVD with an application like Roxio Toast, or you can even do it with Disk Utility. The exact method varies depend on which version of OS X you are using.
    Not hard to do, but you’d probably be better off buying a SuperDrive off Ebay, etc, rather than an external DVD burner, in my opinion.
    Tony!
  • Craig Alan
    January 22, 2006 at 1:59 am
    the new idvd 06 can.
    OSX 10.3.8; Quicksilver Dual 1 gig; FCP 3.0.4; Sony camcorder vx2000; write professionally for a variety of media
