Activity › Forums › Apple Final Cut Pro Legacy › can i work with anamorphic viewer and canvas ?
Posted by Paolo Mugnaini on October 7, 2006 at 2:20 ami started a project and after i digtized it i started working on it and it was anamorphic 16:9 then it changed i don’t kow what did but i couldn’t change it back . i tried not saving the project but it didn’t change.
what do i do?
i feel like an idiot-
thanks
pEnzo Tedeschi replied 19 years, 11 months ago 3 Members · 8 Replies -
Richard Harrington
October 7, 2006 at 3:39 amMake sure your sewunce settings are set to anamorphic…
If footage is supposed to be anamorphic (and is not)… checkk the anamorphic column in the bin
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
Enzo Tedeschi
October 7, 2006 at 3:43 amPaolo,
A lot of Avid editors feel the way you do when first making the switch. Don’t stress, it’s just a matter of learning to think a little differently. 🙂
Unlike the Avid, FCP will let you have multiple sequences in various different formats within the one project. That includes anamorphic settings.
When you start a new project use the easy setup to get started. If you have a 4×3 setup in your preferences, each new sequence you create will be 4×3. If you change that sequence — AFTER you’ve created it – to anamorphic, then it will be 16×9, but any new sequence will still default to 4×3. Make sense?
This may or may not be what has happened – but it may help.
Check this by looking at the sequence’s “Anamorphic” tick box in your browser. Ticked will display as 16×9, unticked is 4×3. You can change that right in the browser.
Be aware that if you drop, say anamorphic clips into a 4×3 sequence, FCP will automatically arc it and add the letterboxing. If you change the clip’s anamorphic flag AFTER you’ve dropped it into a sequence, it will not change the clip as it appears in the sequence, and you will need to fiddle with the actual cut to get it right…
Hope this has been helpful – and keep up the books. Believe it or not it’ll help!
Enzo Tedeschi
____________________________
Editor
http://www.outpostpps.com
Sydney, AustraliaCheck out our latest music video – http://www.outpostpps.com/thebleed/
Look out for the Outpost PPS Video Podcast launching in October
Enzo Tedeschi
October 7, 2006 at 3:44 amSorry, Richard, don’t mean to repeat – you just beat me to the submit button!
Enzo Tedeschi
Editor
Paolo Mugnaini
October 7, 2006 at 4:48 amEnzo, thank you
but what should my window setting be in order to see it anamorphic? fit to….?
thanks for the help. i’m trying here…. hard. 😉
paolom -
Richard Harrington
October 7, 2006 at 5:52 pmNo problem… I as tired and brief… we said same thing (but yours was more in-depth)
-Rich
Enzo Tedeschi
October 7, 2006 at 11:34 pmUnless I am doing some FX work and I need to get in close, I usually leave both my window settings to “Fit To Window”. That way FCP will scale to your window size regardless of aspect. It will also re-scale if you resize your windows.
Enzo Tedeschi
Editor
Enzo Tedeschi
October 8, 2006 at 3:59 amYou’re welcome.
Enzo Tedeschi
Editor
