can I use video event pan/crop effect with Excalibur multicam
Posted by Wayne Grauel on May 20, 2007 at 9:30 pmdoes video even pan/crop work with tracks set up in excalibur multicam
Edward Troxel replied 18 years, 12 months ago 3 Members · 4 Replies -
Edward Troxel
May 21, 2007 at 12:06 pm -
Wayne Grauel
May 21, 2007 at 12:15 pmEd.. was not sure because i could not see any evidence in the “preview tally screen”..
do I just compose a crop in the required camera track (after creating sync points and during the switching process – and then it takes care of itself.. not showing up in the tally view?
may have to set up a couple of tracks and try again…
Vegas 6 and exc. 5…
Thanks Ed..Wayne
Don Bloom
May 21, 2007 at 2:38 pmI find that sometimes I forget to label the tracks 1,2,3, etc and when I do that Excalibur won’t resize the tracks because it doesn’t know which tracks to resize-not saying that’s it but make sure you have labeled the tracks including the audio tracks.
Don
Edward Troxel
May 21, 2007 at 3:12 pmYou definitely want Excailbur to do the work for you as it also creates the additional tracks (and the tallys that appear on those tracks). If you’re adding another clip to the timeline after that was already done, you could copy one that’s correct and then “Paste Event Attributes” to the new clip. However, I just make sure they’re all on the timeline first.
