Activity › Forums › Apple Final Cut Pro Legacy › can i use .qtz effects in final cut pro?
Posted by Phil Beeken on November 17, 2008 at 7:15 pmi got a bunch of .qtz effects for ichat and although there real cheesy i love em!
i was wondering if i could use them in final cut pro in at all?Phil Beeken replied 17 years, 10 months ago 4 Members · 7 Replies -
Tapio Haaja
November 17, 2008 at 7:21 pmWell you can turn Quartz Composer files to Final Cut Pro (or Motion or After Effects) filters, generators or transitions with Noise Industries FxFactory Pro (https://www.noiseindustries.com/). I have build some simple generators and filters with Quartz Composer and FxFactory Pro and it’s relatively easy if you know the basics of Quartz Composer.
Phil Beeken
November 17, 2008 at 7:34 pmthanks for the speedy reply i wonder if anyone knows any other way as at the moment im on OSX 10.4.11 so fxfactory pro will not work…. plus im quite poor…. i wonder if there is any other way??
eek i feel this may be a tricky thing to do….
Tapio Haaja
November 17, 2008 at 7:40 pmWell there’s also cheaper alternative called CVH QC Integration FX which should work in Tiger. It lacks some features but should be fine in your situation.
https://www.chv-plugins.com/cms/FxPlug/QC-Integration/QC-Integration.php?navanchor=1010038
Gabriele De simone
November 17, 2008 at 9:30 pmFxFactory 2.0.3 will work on Tiger systems, and support Final Cut Pro 5.1.2 and Motion 2.1.2 as well:
https://www.noiseindustries.com/support/fxfactoryupdates/files/fxfactory_203.html
As Tapio kindly pointed out, it is relatively easy to create plug-ins if you already have a composition. Although you need Pro to do this, our trial version lasts 15 days so you should be able to create and use something quickly enough, within the free trial.
Regards,
Gabe
Noise Industries, LLC -
Andy Mees
November 18, 2008 at 9:18 amPhil,
Try just placing the .qtz file directly in the timeline
Andy -
Tapio Haaja
November 18, 2008 at 11:58 amYou can bring some .qtz files (screensavers, animations etc.) straight to timeline but Phil is talking about iChat effects (which should work as filters) and you’ll get only black screen if you bring those to FCP.
Phil Beeken
November 20, 2008 at 4:13 pmthank you every one for responding i think my best option is to get an old version of fxfactory which fortunately the site still holds and just run the demo and play around with that…. shame its so expensive!!
