Activity › Forums › Avid Media Composer › Can i Use PLURALEYES with link AMA files or i have to transcode ?
  • Can i Use PLURALEYES with link AMA files or i have to transcode ?
    Posted by Diaa Amer on February 21, 2013 at 12:33 pm
    i am using 5D to shoot and a zoom recorder for the sound .. i used Pluraleyes before to link it worked for some sequences and some not .. My work mates told me to transcode everything first before i sync .. (( i will transcode everything in DNX120 and audio to 48 – If needed ))
    Michael Phillips replied 13 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Richard Sanchez
    February 21, 2013 at 4:26 pm
    Transcode first, auto sequence the audio and video clips, kick out an AAF and plural eyes. Autosync those, and you’re good.
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Michael Phillips
    February 23, 2013 at 6:37 pm
    Or just use DualEyes and prep the sources before coming into MC via AMA.
    Michael
  • Diaa Amer
    February 24, 2013 at 12:02 pm
    But is it a need to transcode ?
  • Michael Phillips
    February 24, 2013 at 4:20 pm
    If you use DualEyes, it is not a transcode as you are syncing the original camera .mov files with the audio files and have options to replace .mov audio with double system audio, or sync all elements by giving them a common start frame by truncating or padding audio files to match video.
    If you use AMA, bring into Media Composer, and want to use PluralEyes, then it is a transcode first.
    Michael
  • Diaa Amer
    February 24, 2013 at 4:30 pm
    last Question, i did a link AMA, and exported Aff sequence .. and the sycing worked sometimes, that mean i got lucky, cause i really have tons of material and transcoding is not a good option ..
    My question do i just try to get Dual eyes to save time and not to transcode ?
  • David Powell
    February 24, 2013 at 9:22 pm
    Plural eyes 3 allows for AMA syncing. If you are laying out the clips on the timeline and subcipping them, what would be the advantage of transcoding before syncing? Wouldn’t transcoding afterwards give you a more trimmed down selection similar to creating selects before transcoding any other way?
  • Michael Phillips
    February 24, 2013 at 9:36 pm
    I haven’t used PluralEyes 3, but it may be more to do with AAF export from AMA connected sources which is why a transcode is done beforehand. I haven’t tried AMA with Edit Protocol and if third parties can use that as part of their process. Has anyone here actually done this?
    Also, audio only files should always be imported, and not AMA’d…
    Michael
