Activity › Forums › Apple Final Cut Pro Legacy › Can I use masks from Photoshop in FCP?
Posted by Chris Davis on July 6, 2009 at 7:05 pmWondering if I can just make masks in Photoshop and use them directly in FCP. I would be using them to, for example, make the background out of focus on a shot where the subject is relatively stationary.
Or can this kind of thing only be done in AE/Motion?
Thanks.
Chris Davis replied 17 years, 2 months ago 4 Members · 4 Replies -
Shane Ross
July 6, 2009 at 7:29 pmFCP has this capability, albiet a bit primitive. There is the Garbage Mattes, 4 and 8 point. But then Paul Crisp made 32 and 64 point ones (Google them).
Or you can do this in Motion…draw a mask shape.
Shane
Read my blog, Little Frog in High Def -
Jason Diebler
July 6, 2009 at 8:15 pmConsider if you will need to keyframe your mask, if so, then you want to stay in FCP or Motion.
“The deepest blues are black” – Foo Fighters
(this doesn’t help me when I’m chroma keying!) -
Victor Perez
July 6, 2009 at 8:32 pmI use mattes made in photoshop on various projects to add an additional element (GFX) to a certain area of the screen for Text.
Place the matte on V-2 / A copy of the clip on V-3 / Add the Composite Mode – Travel Matte Luma to the clip on V-3 / Add your effects to either the clip on V-1 OR the clip on V-3 for the look you want.Lately I have found that sending clips to Apple Color gives me a more believable image if I want something blurred in the background. It takes a bit of prep work to start, and is well worth it if you have the time, but lately the process has been getting faster and faster as I increase the number of clips I send to Color.
good luck,
Victor
Chris Davis
July 8, 2009 at 10:53 pm[Shane Ross]
“…There is the Garbage Mattes, 4 and 8 point. But then Paul Crisp made 32 and 64 point ones (Google them).”Thanks.
[Victor Perez]
“…I use mattes made in photoshop on various projects to add an additional element (GFX) to a certain area of the screen for Text.
Place the matte on V-2 / A copy of the clip on V-3 / Add the Composite Mode – Travel Matte Luma to the clip on V-3 / Add your effects to either the clip on V-1 OR the clip on V-3 for the look you want.”I appreciate the detailed response. I’ll give it a try.
-Chris
