Activity Forums Avid Media Composer can i stretch 4:3 footage to fit 16:9?
  • can i stretch 4:3 footage to fit 16:9?
    Posted by Milton Hockman on April 1, 2007 at 9:46 pm
    i am using 4:3 footage in a 16:9 sequence, and to make it look correct i used a resize filter to boost the height to 125.
    The footage looks clean to me and it seems like i found a method to make all my 4:3 projects fit into 16:9 space.
    am i missing something here? maybe there is artifacting i am not seeing or what?
    what do you think about this process?
    Sebastian Riezler replied 19 years, 5 months ago 3 Members · 2 Replies
  • Michael Phillips
    April 1, 2007 at 11:15 pm
    That should do it – there is also a Pan & Scan effect in the Reformat section of the effects palette. Drop it on, go to the parameters and select 4:3 as source and 16:9 as target and it will do the same thing with the added benefit of a tilt and scan effect to get the best composition for the shot.
    Michael
    anything 24fps
  • Sebastian Riezler
    April 2, 2007 at 11:43 am
    great tip michael.
    thx
