Activity › Forums › Adobe After Effects › Can I stream particles from a partial mask?
  • Can I stream particles from a partial mask?
    Posted by Mark Landsburger on July 10, 2005 at 9:24 pm
    Hi all,
    I’m trying to figure out how I can have particles stream from a long line, but I can’t seem to work it out. I have Particular, but I can only seem to have the birth point be a single point and not attach it to a drawn line (for instance).
    Suggestions? Can it be done?
    Thanks a bunch,
    LB
    Mark Landsburger replied 21 years, 2 months ago 2 Members · 2 Replies
  • Steve Roberts
    July 10, 2005 at 11:50 pm
    Draw the mask on a solid, then apply effect>render stroke, using “on transparent” as the paint style. Precompose this layer, selecting “move all attributes”.
    Next, apply Particular to a solid. With the emitter type as “layer”, use the above precomp (the stroke)as the emitter.
    Steve
  • Mark Landsburger
    July 11, 2005 at 12:21 am
    Thank you thank you thank you Steve
