Activity Forums Apple Final Cut Pro Legacy Can i still zoom into the image on the canvas after the white, square pulltabs are gone?
  • Can i still zoom into the image on the canvas after the white, square pulltabs are gone?
    Posted by Noam Osband on February 5, 2012 at 8:58 pm
    When I have the wireframe on, I like to zoom in by pulling on them. However, after they are out of view, I can’t do this and then to zoom in i need to use the tclip’s tab in the viewer. this makes it laborious and trial and error to make sure it’s as zoomed in as i want. is there a better way to do this? after the little white squares on the corners i can pull are gone, can i still zoom in and out in the wireframe mode?
    Tom Matthies replied 14 years, 7 months ago 3 Members · 2 Replies
  • Neil Patience
    February 5, 2012 at 9:44 pm
    One way is to use the scale button at the top of the canvas.
    Just make the picture smaller and then you have much more room to see your zoom.
    Or click the canvas and use the apple+/- command to make it bigger or smaller.
    best wishes
    Neil
    http://www.patience.tv
  • Tom Matthies
    February 6, 2012 at 2:25 pm
    If the wireframe mode is still enabled, display your window in a size smaller than normal. This will allow you to see the handles on the wireframe even if they are outside of the frame edges.
    E=MC2+/-2db
