Activity Forums Adobe Premiere Pro Can I somehow bring a simple FCP project into Premiere Pro?
  • Can I somehow bring a simple FCP project into Premiere Pro?
    Posted by Phillip Roh on December 22, 2007 at 12:02 am
    Hello, I have a simple FCP project. It’s all straight cuts from 2-angle multiclips. All media is either DV-NTSC quicktime movie files or 48 khz/16 bit AIFFs. No filters, some normal video dissolves and audio cross fades. Can I somehow convert a FCP project file into something that Premiere Pro can import? Any media-related problems I should be aware of?
    Jon Barrie replied 18 years, 8 months ago 5 Members · 5 Replies
  • Aanarav Sareen
    December 22, 2007 at 4:10 am
    You can’t import a FCP project into PPRO. Does FCP export to EDL?
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Jon Barrie
    December 22, 2007 at 7:07 am
    FCP does do EDL.
    1. Export an EDL from FCP project
    2. Import EDL into a DV NTSC PPro project
    3. Recapture the footage.
    4. Try to link it to the original footage, but that will probably not be accurate. (for many reasons).
    5. Recapture with extra long handles to keep the ability to reedit.
    NOTE:
    FCP and PPro will only talk clearly with EDL, but that is a defined list of cuts not the original captured footage. Which is why you need to recapture.
    – Jon 🙂
  • Jeff Brown
    December 22, 2007 at 8:08 pm
    Will FCP export an AAF file? Premiere can import AAF, though it does not always work. AAF is apparently pretty unrefined vis-a-vis compatibility. A CMX EDL might be more reliable.
    Another possibility is FCP –> OMF file, OMF into AfterEffects, AE –> Premiere. (good luck if you try it!)
    -jeff
  • Nickhodemus
    December 29, 2007 at 12:01 pm
    Also remember there are subtle nuances with the FCP format EDL and the Premiere Pro. It almost certainly never works by just using the export -edl commands.
    Check out this link:
    https://www.scottsimmons.tv/blog/2006/10/12/how-to-read-an-edl
  • Jon Barrie
    December 29, 2007 at 9:44 pm
    Nested Sequences and Multiclip info won’t EDL. You can only EDL properly straight footage.
    – Jon 🙂
