Activity Forums Apple Final Cut Pro Legacy Can I search just sequences?
  • Can I search just sequences?
    Posted by Noam Osband on October 22, 2011 at 4:52 pm
    I have a ton of sequence names in my project. Sometime i need to find one and I cant in my browser so i want to search the browser just for sequences by name. Is there a way to do that?
    Neil Patience replied 14 years, 10 months ago 2 Members · 1 Reply
  • Neil Patience
    October 22, 2011 at 6:26 pm
    I dont think you can search just sequences but you can certainly search under quite a few criteria.
    Under the “edit” menu select “find”
    Then enter the parameter you would like to search, you can leave it on “any column” or pick something more specific from the list – perhaps “name” in your instance.
    Then select “find all” you will then get a new browser window filtered by your search criteria.
    So as long as you know the name of the sequence you want to find it will be there (along with any other clips containing the same name.)
    Certainly narrows down your search a lot.
    Hope that helps
    best wishes
    Neil
    http://www.patience.tv
