Activity Forums Panasonic Cameras Can I run other decks through the HD1400 and into my comp via Firewire
  • Can I run other decks through the HD1400 and into my comp via Firewire
    Posted by Zach Graber on August 13, 2007 at 8:13 pm
    I was wondering if i can run sd footage out of a beta deck through the HD1400 deck and into my comp via firewire?
    Noah Kadner replied 19 years ago 3 Members · 2 Replies
  • Jeff Merritt
    August 13, 2007 at 10:29 pm
    The HD1400 is an HD deck only for input and therefore you can not send an SD signal into the machine and expect it to convert SD to HD. It will not accept an SD signal on the input. Likewise, it is not possible to format convert the output of the machine on the firewire port. The 1394 outputs only the original signal format recorded on tape either SD or HD. The input via 1394 is HD only.
    I hope this clears this up for you.
    Jeff Merritt
    Product Line Business Manager
    High Definition Products
    Panasonic Broadcast
    323-436-3676
  • Noah Kadner
    August 14, 2007 at 2:57 am
    Get thee to AJA.com. 🙂 PS- GREAT to see ya Jeff. 🙂
    -Noah
    Unlock the secrets of the DVX100 and now Apple Color!
    https://www.callboxlive.com
