Activity Forums Adobe After Effects can I render in a PC using 3th part plugins for mac?
  • can I render in a PC using 3th part plugins for mac?
    Posted by Gerardo Flores on May 3, 2010 at 1:25 pm
    Hi I know that maybe is a stupid question,
    but I just want to know if some of you have any solution?
    What is more demanding for rendering RAM or CPU
    and how I can improve the CPU of my MAC
    best regards
    Thats my real name 🙂
    Gerardo Flores replied 16 years, 4 months ago 2 Members · 3 Replies
  • Kevin Camp
    May 3, 2010 at 2:56 pm
    you would need the windows equivelent plugins (most developers make mac and pc versions of their effects).
    as for performance benefits, cpu is most important (both speed and number of cpus/cores). ram can help, esspecially if it allows you to use more cores for rendering – the genereral rule is 2-4gb per core, so you can do the math for your system. with cs5, ae can use even more ram than that.
    as far as upgrading the cpu, some macs do have socketed cpus that can be upgraded. you would need to search the web to see if yours is one of those, and the process involved to upgrade it. you might also weigh the option of selling your current system and getting a faster one.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Gerardo Flores
    May 3, 2010 at 6:25 pm
    thank you a lot
    G.
  • Gerardo Flores
    May 10, 2010 at 12:39 am
    actually NOT
    if you are using noise indrustries effects you can NOT
    render in any other PC just MAC
    learning after effects
