Activity Forums Blackmagic Design Can i read out the VANC data from an SDI Stream?
  • Can i read out the VANC data from an SDI Stream?
    Posted by Steffen Boerner on January 28, 2009 at 1:01 pm
    Hello,
    i want to get the Timecode coming in the VANC data of an SDI Videostream. The Video comes from an RED Camera which put the Timecode in the SDI Data. I have a HD Extreme and want to know whether it’s possible to read out the Timecode.
    Kind regards
    Mike Reddy replied 14 years, 9 months ago 3 Members · 2 Replies
  • Margus Voll
    January 31, 2009 at 10:01 am
    Hi.
    It seemes that RED is the key part here as BM should read vanc trough SDI. I have done it with digibeta and SDI.
    But why use SDI with RED enyway ?
    Margus
    https://iconstudios.eu
  • Mike Reddy
    November 15, 2011 at 3:08 am
    Yes absolutely. Reading the VANC data from an SD-SDI or HD-SDI stream (that includes Closed Captioning data) is often of great help – it is necessary in order to verify CC, to monitor things like AFD or Broadcast Flag, to capture VANC info such as CC data to a separate file, etc.
    Vela Research has solutions, one of which is called ArgoNavis, geared to monitoring, verifying and/or capturing VANC data from SDI streams.
