Can I preset the Pan/Crop to 16:9 Widescreen Aspect?
Posted by Norman Willis on July 19, 2009 at 5:37 pmIs there some way to set the default on the Pan/Crop feature to come up in 16/9 Widescreen aspect ratio, since my default intended target is Vimeo/YouTube?
Thanks.
Norman Willis
http://www.nazareneisrael.org
se*****@************el.orgNorman Willis replied 16 years, 10 months ago 3 Members · 5 Replies -
Theo Van laar
July 19, 2009 at 6:34 pmIf there are things you have to apply to many events, you can use scripts to enhance your workflow.
Here is a script to use for matching aspect ratio. I don’t know who wrote it, but just try and see if it works in your version of Vegas. (If you don’t know how to apply scripts, we can explain to you).
Theo
Norman Willis
July 19, 2009 at 6:57 pm>>(If you don’t know how to apply scripts, we can explain to you).
Yes, please.
John Rofrano
July 19, 2009 at 7:14 pmIf you set your project up as 16:9 then you can just right-click on the frame in Pan / Crop and select Match Output Aspect. This will guarantee that your aspect is correct.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Theo Van laar
July 19, 2009 at 10:01 pm‘>>(If you don’t know how to apply scripts, we can explain to you).
Yes, please.
Hi Norman,
Download the script you would like to use (there are many free scripts on the internet, including the matchaspect script: 148_matchaspect.js.zipUpzip the script (if nessecary) and copy it into C:/program files/Sony/Vegas x.0/Script Menu.
Open your Vegas project.
Select all the events you would like to match aspect ratio (or whatever kind of script you would like to perform).
Go to TOOLS-SCRIPTING and click on the desired script. That should do the trick on all the selected events.
In case you added the script while Vegas was already open, you will first have to go to TOOLS-SCRIPTING-RESCAN SCRIPT MENU FOLDER to make the new script available.
To place the icon for a certain script available on the toolbar (very handy if you use it often), go to OPTION-CUSTOMIZE TOOLBAR (or just doubleclick on the toolbar).
The window that opens is selfexplaning.
Once you have experienced the big advances and timesavings of scripts, you might start looking for things like Excalibur, Ultimate S or Vegas Production Assistant.Theo
Norman Willis
July 20, 2009 at 3:04 am
