Activity Forums VEGAS Pro Can I make this type of MPEG-2 in Vegas 6.0?
  • Can I make this type of MPEG-2 in Vegas 6.0?
    Posted by Nosoapradio on April 29, 2006 at 2:27 pm
    So I’m doing my first spot for Broadcast and the media distributor is asking for a specific type of MPEG-2 to upload to their facility. I’m creating most of it in AE, then I’ll bring an uncompressed AVI into Vegas 6 to make the MPEG-2. Can I encode this with Vegas, or do I need a more specialized application? Here are the specs:
    Encoding – MPEG-2
    Min – 10 Mb/s
    Max – 25 Mb/s
    Preferred – 25 Mb/s
    Scanning – 480 60i (upper field first)
    Pixel Aspect Ratio – 0.9
    Aspect Ratio – 4×3
    Chroma – Min – 4:2:0 (MP@ML) (720×480)
    Chroma – Preferred – 4:2:2 (422P@ML) (720×512)
    GOP – All Allowed, IBBP preferred
    Frames per second – 29.97 (NTSC)
    Stream Type – Program Stream
    Audio-MPEG-1, Layer 2 – 384kb/s Stereo
    Audio-Dolby AC3 – NA
    AVG Digital Audio Level – -17dBfs
    AVG Analog Audio Level – +4dBm
    Luminance Level Max – 100 IRE
    Chroma Level Max – 120 IRE
    Setup level – 7.5 IRE
    Timecode – Non Dropped Frame
    Also, how would I QC this type of file?
    Thank you so much in advance,
    Radio
    Nosoapradio replied 20 years, 4 months ago 2 Members · 2 Replies
  • Gary Kleiner
    April 29, 2006 at 3:43 pm
    You should be able to me these specs using Vegas though you won’t be able to hit 25Mbps (the max bitrate is 15Mbps which is still within your spec).
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Nosoapradio
    April 29, 2006 at 3:52 pm
    Thanks. Now is the 15Mbps limit, is that a Vegas limit or a limit of the format? Also, any recommendation on checking this file to see if it looks good on TV? I don’t have a specialized video card (like Decklink), just firewire, and a dual head Matrox.
    Thanks for the help,
    K
