Activity Forums Adobe Premiere Pro Can I make a stereo sequence mono or do I have to re-edit all the audio?
  • Can I make a stereo sequence mono or do I have to re-edit all the audio?
    Posted by Christine Edwards on February 20, 2014 at 4:00 pm
    I’ve made a bunch of multicam clips and cut them int oatimeline, but I’m realizing now I should have broken the audio into dual mono so I can get rid of the off mic track. Is there a way to do this or do I have to start over??? Coming from Avid this is insane to not be able to turn a stereo track in a timeline into a mono track. There must be some way to do it?
    Macbook 2.7 Ghz Intel Core i7 / 8GB 1600MHz DDR3 / NVIDIA GeForce GT650M 1024 MB graphics / Apple Thunderbolt Display /
    OS X 10.8.4
    Dave Brandt replied 12 years, 6 months ago 2 Members · 1 Reply
  • Dave Brandt
    February 20, 2014 at 10:03 pm
    Hi Christine.
    There is an effect in the audio effects section called ‘fill left’ and ‘fill right’
    apply this to your clip to fill the respective audio channel with the other.
    It’s a bit confusing and should have been called ‘fill with left’ for example if i want the left channel only to be heard I use fill left and vice versa.
    You can apply this to the audio in your original multi clip sequence or else just keep editing away and apply it to all clips in your audio track later on.
    Hope that helps
    Dave
    http://www.BrandtStudios.ie
    Macbook Pro Retina 15″ i7 2.7 16GB Early 2013
    PC i7 32GB Self Build
    FCPX LogicX Adobe CC Vegas 12 Nuendo 4
