Activity › Forums › VEGAS Pro › Can I make a loop point in DVDA 2?
  • Can I make a loop point in DVDA 2?
    Posted by Nomar25 on January 11, 2006 at 8:14 pm
    I don’t know where to access this. Can someone show me real quick? I have DVDA 2 and can’t find how to make a loop point for my motion menu. Thanks! I know that DVDA 3 can do this, but what about 2?
    Gary Kleiner replied 20 years, 8 months ago 3 Members · 6 Replies
  • Edward Troxel
    January 11, 2006 at 8:32 pm
    In the menu properties, you set the “length” of time the menu is to play. It will then loop at that point if you have set the menu up to loop. I believe it’s in the same place in both DVDA2 and DVDA3 (I’d have to open both to verify except DVDA3 had better separated categories) – just in the menu properties.
    Edward Troxel
    JETDV Scripts
  • Gary Kleiner
    January 11, 2006 at 9:36 pm
    As Edward says, you can set the menu to loop in DVDA 2, but you cannot create a menu that loops from a point other than the beginning as in DVDA 3.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Nomar25
    January 11, 2006 at 10:08 pm
    Thanks guys. I need to loop the menu at a point that is not at the beginning. So I guess I got to get DVDA 3. Oh well.
  • Edward Troxel
    January 11, 2006 at 10:15 pm
    Oh, you meant the BEGINNING (thank’s Gary). You could always render the piece you want looped out separately in Vegas.
    Edward Troxel
    JETDV Scripts
  • Nomar25
    January 11, 2006 at 10:54 pm
    Yeah, I thought of that too. Tried it from Vegas and worked fine, except that the button highlight for the selected state was “on” the whole duration of the menu. In Encore and DVDSP, the highlighted button in its selected state would only appear once it rolls over the loop point. I would assume that works for DVDA 3, right?
  • Gary Kleiner
    January 12, 2006 at 2:23 am
    [Nomar Knows] “the highlighted button in its selected state would only appear once it rolls over the loop point. I would assume that works for DVDA 3, right?”
    Right.
    Gary Kleiner
