Activity Forums Adobe Premiere Pro Can I Make a Dip to White Preset?
  • Can I Make a Dip to White Preset?
    Posted by Dowhite on August 14, 2005 at 4:13 am
    It’s odd that PPro has a transition for “dip to black” and not one for “dip to white”. Is there any way to make a preset for this type of a transition?
    Thanks.
    Dowhite replied 21 years ago 3 Members · 3 Replies
  • David J
    August 14, 2005 at 8:31 am
    One way would be to create a sequence containing just the ramp to and from white and then place this on top at the point where you want the ‘transition’ in the main sequence.
    By saving this in a separate project, you can import it for use in the future.
  • Steven L. gotz
    August 14, 2005 at 7:44 pm
    Or, you can create a preset from the opacity control. Then just apply that preset to any white matte of any duration, and it will scale properly.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Dowhite
    August 22, 2005 at 3:23 am
    Thanks for the ideas!
