Activity Forums Adobe After Effects Can I make 60fps 7D footage look like 24 Fps? Using After Effects
  • Can I make 60fps 7D footage look like 24 Fps? Using After Effects
    Posted by Richard Pengelly on November 19, 2011 at 5:14 pm
    I shot my first music video on the 7D and we were doing 60Fps shots for slow motion. One of the cameras did not get Switched back to 24FPS when we went on to our lip sync shots. The realtime 60fps video obviously looks far to much like video. Can I some how give the footage a 24 fps look?
    I am using FCP 7.0.3 to edit.
    Richard Pengelly
    Funkin it up Old School
    Chris Wright replied 14 years, 9 months ago 3 Members · 3 Replies
  • Erik Waluska
    November 19, 2011 at 8:57 pm
    One thing you could try is to pre-compose the 60fps footage in a comp set to 60fps and go to the comp settings>advanced tab and check “preserve frame rate when nested”. Then nest that comp inside of a 24fps comp and see how it looks. It might be a little jerky or it might look fine since it does have 60 frames to work. You’d just have to try it and see.
  • Richard Pengelly
    November 19, 2011 at 9:01 pm
    Thanks I will give that a try. It looks like the G Film filter I have now can do it but it needs interlaced footage and I shot in progressive. I found an old cow forum that explains how to switch Progressive to interlaced.
    If you have any suggestions on how to interlace progressive that would be great
  • Chris Wright
    November 20, 2011 at 12:31 am
