Activity Forums Apple Final Cut Pro Legacy Can I look at a clip and see which sequences it is in?
  • Can I look at a clip and see which sequences it is in?
    Posted by Noam Osband on June 6, 2013 at 5:03 pm
    I have a huge project file, with a ton of clips and many sequences. I want to search to see if a particular clip is used in any sequences. How can I do that?
    Shane Ross replied 13 years, 3 months ago 2 Members · 3 Replies
  • Shane Ross
    June 6, 2013 at 5:33 pm
    Open a sequence, press CMD-F..type in the name of the clip. Repeat in all the other sequences.
    Shane
    Little Frog Post
  • Noam Osband
    June 6, 2013 at 5:40 pm
    can i do this without opening sequences? i have a ton of sequences and am wondering if i can search without needing to open them.
  • Shane Ross
    June 6, 2013 at 5:41 pm
    No…you need to open them.
    Or you can highlight them, export them as XML, import them into an application called Sequence Clip Reporter (intelligentassistance.com) and search the file it makes. But the first option is free, and faster.
    Shane
    Little Frog Post
