Activity › Forums › Apple Final Cut Pro › Can I keyframe and increase over time a color correction?
  • Can I keyframe and increase over time a color correction?
    Posted by Noam Osband on August 18, 2016 at 5:00 pm
    I filmed an interview using natural light and the clouds occasionally got in the way so I need to boost the exposure of some of the levels. That said, it happens gradually and I dont want to give my client a video where the color suddenly jumps.
    Any way to keyframe a color correction so I have it come and go gradually? If I can’t do this with FCP X, can I do this with Color Finale? I was thinking of getting it anyways and this might put me over the edge.
    thanks!
    Noam Osband replied 10 years ago 4 Members · 5 Replies
  • Bret Williams
    August 18, 2016 at 5:19 pm
    Can’t do it natively with X. Best you can do with the color board is blade the clip, have two different settings on each clip, and dissolve between them.
    _______________________________________________________________________
    https://BretFX.com Plugins & Templates for FCP X Editors & Motion Graphics Artists
  • Noam Osband
    August 18, 2016 at 5:20 pm
    Any plugins that will let me do this?
  • Fedor Von hengstenberg
    August 19, 2016 at 1:11 pm
    Probably the easiest way to achieve what you want is to place a copy of the clip on top of the original as a connected clip, then do your grading on the copy. You can then regulate the amount of grading by keyframing the opacity of the connected clip.
  • Mark Suszko
    August 19, 2016 at 3:08 pm
    I like Fedor’s approach, but wanted to add, you can also treat this problem in Apple Motion.
  • Noam Osband
    September 28, 2016 at 7:47 pm
    Is it possible to do something like this with Color Finale?
