Activity › Forums › Blackmagic Design › Can I Join Two Studio Videohub’s Together?
  • Can I Join Two Studio Videohub’s Together?
    Posted by Jack Jones on May 22, 2010 at 3:24 pm
    I’m in the process of designing our new machine room and the cabling infrastructure to go with it.
    I started up a design based around a 32 channel patch hub, which is pretty much all we currently need, plus and extra 4 spare slots. I’m planning on sending everything, including the GUI’s over SDI into the suites utilising DVI-to-SDI and back convertors.
    In summary. Is it possible to buy two BMD Studio Videohub’s and connect them so they’re both completely workable?
    Example; ‘Suite 1 on Board 1 takes Deck 1 on Board 2’ whist simultaneously ‘Suite 2 on Board 1 takes Monitor 1 on Board 2’
    Hope that’s sort of clear!
    Jack
    Kristian Lam replied 16 years, 4 months ago 2 Members · 2 Replies
  • Jack Jones
    May 22, 2010 at 3:50 pm
    Alternatively… Is it possible to do the following;
    On Channel 1 is Edit 1 and Monitor 1
    On Channel 2 is Edit 2 and Monitor 2
    Is it possible to do Monitor 2 takes Edit 1*????
    *Possibly by doing Mon 2 takes SDI Out from Channel 1
    Any help would be nice, I’m planning on giving BMD a call early next week for some numbers etc.
    Jack
  • Kristian Lam
    May 24, 2010 at 12:19 pm
    If you are thinking of doubling up the routes, then you’ll really need 4 units to get the full matrix, however, if you’re thinking of sending signals from one router to another rough some creative routing, that’s still possible.
    regards
    Kristian Lam
    Blackmagic Design
