Activity Forums Adobe After Effects Can I increase the amount of RAM AE3 uses?
  • Can I increase the amount of RAM AE3 uses?
    Posted by Peter Rafalow on May 25, 2011 at 9:46 pm
    On both of my Macs, AE3 preferences says I have 3GB of RAM. On one system I have 13GB of RAM, and on the other I have 6GB of RAM.
    Is AE3 limited to using 3GB of RAM, or can I increase this to speed things up? Rendering HD comps are tough! Thanks for anyone’s help!
    Peter Rafalow replied 15 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 25, 2011 at 10:07 pm
    You can’t access more RAM than that because AE CS3 is a 32-bit application. AE CS5, the first 64-bit application, can address all the RAM in your system.
    That said, if you have a multi-core system, and 2-4 GB per core, you can enable multiprocessing [link]. This will help you render faster by launching multiple instances of the AE renderer at the same time. See the notes below the linked article in the docs for information on how to restrict the number of cores AE CS3 uses if you find yourself running out of RAM.
    Walter Soyka
  • Peter Rafalow
    May 26, 2011 at 10:58 am
    Thanks for the help and advise!
