can i import mp4 into DVD Architect?
Posted by Gilles Gagnon on September 17, 2012 at 5:57 pmI need to create a DVD. I have mp4 files rendered with the Main Concept template. I know normally I should be rendering to mpg2 and ac3 to create a dvd. Is it still possible to do this given that it’s not meant as a copy to be given to a client?
I attempted it but the result was that the video’s sound was replaced by static noise.
Can someone shed some light please?
cheers,Gilles
Mike Kujbida replied 13 years, 11 months ago 2 Members · 11 Replies -
Mike Kujbida
September 17, 2012 at 6:13 pmGilles, it sounds like you’re trying to get out of doing more work again 🙂
Unless you do this as a data file on a DVD (i.e. meant only for computer playback), you still have to do an MPEG-2/AC-3 render.
Your other option is to do it straight from the Vegas timeline.
Tools – Burn Disc – DVD. -
Gilles Gagnon
September 17, 2012 at 6:18 pmha ha!
You mean… trying to be as efficient as possible, Mike 🙂
Thanks for confirming what I thought.You’re right, I’m not looking for a data file but an actual DVD.
Hmmm… I like the idea of burning it right from the timeline.
I’m going to try this right now,
Thanks!Gilles
Mike Kujbida
September 17, 2012 at 6:22 pm“You mean… trying to be as efficient as possible”
Gilles, I like that line!!
I use this option for one-off student project DVDs all the time and, as long as the video is 1 hr. or less (this method uses PCM audio), it works great. -
Gilles Gagnon
September 17, 2012 at 6:26 pmuh ho!
Just tried… stumbling block aheaed…I was hoping to have the availability to do only the selection as the timeline’s video is 4 hours!
I guess this method won’t work. Any other ideas?
You see, I’ve already remdered this long timeline in shorter mp4 segments. I was hoping to just import them in DVDA. and burn a couple of DVDs.
Gilles
Mike Kujbida
September 17, 2012 at 6:29 pmCopy/paste the relevant selection to a new instance of Vegas and do it from that one.
Keep in mind that any track level video FXs (i.e. Track Motion) will NOT get copied over 🙁 -
Gilles Gagnon
September 17, 2012 at 6:36 pmHey Mike,
What’s the longest video I can burn using this method?
I just tried 1/2 the project, about 2:15 hours, and it stated it would require 10GB…Gilles
Mike Kujbida
September 17, 2012 at 6:38 pmGilles, my experience has been that the limit is only 1 hr. because this method creates a PCM audio file, not an AC-3 file which impacts the bitrate.
Gilles Gagnon
September 17, 2012 at 6:45 pmI see…
Thanks Mike. I may have to split the project and render to mpg2/ac3 after all.How do you go about knowing if the mpg/ac3 will fit on a DVD? for 2.25 hours, which bit rate should I select?
Gilles
Mike Kujbida
September 17, 2012 at 7:06 pmI’ve been using the bitrate calculator found at https://www.johncline.com/bitcalc110.zip for a very long time and it’s never let me down.
I make a few changes to the default settings and they are as follows.
Click the Settings button (lower left corner), set 1 kilobit=1000 bits, set Audio encoding type and Bitrate to 192 Kb/s – Dolby 1.0 (the AC-3 default in Vegas) and the Safety Margin to 5% (default is 1% and I like to have more margin than that).Using this calculator (and my changes), I get the following VBR numbers for 2.25 hr.
7,264,000 / 4,152,000 / 2,488,000
Audio is AC-3 at the Vegas default of 192 192 Kb/s.
Due to the length of the program, I’d do a 2-pass render.
It will take longer but the results will be worth it. -
Gilles Gagnon
September 17, 2012 at 7:10 pmValuable info Mike!
Thanks a million!
I’ll give it a whirl.Gilles
