Activity Forums Avid Media Composer can i import larger tifs into a avid project
  • can i import larger tifs into a avid project
    Posted by Dan Jacobsen on October 5, 2007 at 10:00 am
    hi there,
    we’re working on a pal sd avid symphony project. can i import a jpg/tif/tga that is larger than 720×576 and the avid not resize it to fit pal resolution. ie can i zoom into it, in avid, without losing picture quality.
    cheers
    Jon Zanone replied 18 years, 11 months ago 2 Members · 1 Reply
  • Jon Zanone
    October 5, 2007 at 10:40 am
    Use the pan and zoom effect. Go ahead and import your pix, resized to Avid resolution. These are for reference only. Lay them in your timeline and apply the pan and zoom effect. Open the effect editor and click on the small box in the upper left hand corner. Navigate to the ORIGINAL files, picking the one that matches your original. I’m not sitting in front of my Avid, but I use ‘display target’. I also apply a gaussian filter as well. It smooths out some of the chunkies.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
