can i import 12 fps SWF to AE and then export for video at 25 fps?
Hello!
I’m making an animation for both video and web.
The plan is, when it’s done, I will export as swf and take into after effects and output it there.
Should i make the framerate 25fps (i’m in the United Kingdom and it would be shown here, so it’s that as opposed to 29/30fps)or just 12fps?
Unfortunately i don’t have access to after effects til later on in the production schedule so i can’t test.
Does anyone know if After effects can handle SWF at 12fps or must it be 25 fps?
From what i’ve been reading,it would be better to have a lower frame rate for web purposes.
Apologies as I’ve posted this on the flash posting page too cos i need an answer asap.
