Activity › Forums › Apple Final Cut Pro Legacy › can I have FCP5 and FCP 4.5 both installed?
  • can I have FCP5 and FCP 4.5 both installed?
    Posted by Raju Bhai on August 23, 2005 at 3:22 pm
    I have FCP 4.5. I also want to install FCP5. I plan to use both versions, is that possible or would one conflict with the other if they are both installed on the same computer?
    I’m using a PowerBook G4, 1.67 ghz, 17 inch, 2 gig RAM
    Chris Babbitt replied 21 years, 1 month ago 4 Members · 6 Replies
  • Rainer Wirth
    August 23, 2005 at 3:31 pm
    Yes you can. You have to have two systems on two hard discs. I recommend OsX 3.8 for FCP 4.5 and the newest Tiger version with 5. Keep your project seperated from each other. If you have a project in FCP4.5 keep it there, if you started on 5 treat it the same way. You start the computer with one of the systems depending on what FCP you work.
    Rainer
    P.S. FCP 5 needs a clean install with Tiger
  • Raju Bhai
    August 23, 2005 at 3:40 pm
    when u say 2 systems on 2 hard disks, do u mean just the source data and project files for FCP 4.5 should be on a separate disk from FCP5 or that the actual application programs need to be on separate disks? I’m guessing that u mean it’s OK to have FCP 4.5 and FCP5 on the same internal hard disk but that just the project files and all data relating to them need to be separated on different disks.
    please clarify
    thanks
  • Jeff Carpenter
    August 23, 2005 at 3:43 pm
    He means two different boot drives. So you would re-start your computer depending on which Final Cut you wanted to use. It COULD be 2 different discs, or you can re-format a single drive into 2 partitions using Disk Utility (if it’s large enough). You would instal a different OS on each partition and treat each one as if it were a seperate computer within your computer.
  • Chris Babbitt
    August 23, 2005 at 10:23 pm
    I am running both FCP5 and FCP3 on Tiger on the same system drive. Why would it be any different running 4 and 5 together?
  • Rainer Wirth
    August 24, 2005 at 10:33 am
    Jeff is one hundred percent right. Two complete systems on two partitions. You have to restart the computer to work either on 4.5 or 5.
    Don’t mix the two, and don’t mix project files, you end up in a mess, because onco you’ve transferred a 4.5 project into a 5.0 project you have to carry on in 5.0.
    This is the only way I know of that the two systems work reliable.
    Rainer
  • Chris Babbitt
    August 25, 2005 at 2:00 am
    Have you tried it? I have, and it works just fine. I do have separate folders for project files from different versions.
