Can I feed two monitors at once, one via composite and one via HDMI?
I want to feed two monitors at once with my HMC-150. I want to use the HDMI output for one and the composite output for the other. Can i use both at the same time? I’m using it to connect to two different machines, one that has an HDMI input and one with a composite input, so a device that let’s me create two HDMI channels – like this https://www.bhphotovideo.com/c/product/623899-REG/Kanex_HDMISP2_HDMISP2B_1x2_HDMI_Distribution.html – doesn’t solve the problem.
