Activity › Forums › Adobe After Effects › Can I define the emitter’ Shape to generate a stars night sky?
  • Can I define the emitter’ Shape to generate a stars night sky?
    Posted by Chris Gallego on September 9, 2016 at 11:52 pm
    I want to create some star to emulate the milky way in 2d. I used cc particle world but I don’t know how to “freeze”?¿ the animation. I just want the same effect but in static. Is there any way to get it?
    And the other doubt is about the emitter shape. Can I define a lenticular shape a bit bend to give a curved to that lenticular shape?
    For example: If I draw a curve or arch (with pen tool) Can I use or set that stroke like an emitter?
    I hope do you understand my idea and my special English.
    Thanks.
    Chris(tian)
    Chris Gallego replied 10 years ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    September 10, 2016 at 7:37 am
    Use zero velocity for the particles and life span long enough to cover the entire length of the comp. Emit particles for a few frames at a high rate and then turn emission to 0. You can reshape the emitter during the emission to create a bulge at the center.
    When you’re happy with it, push the layer back a few seconds so that the shape is fully formed when the shot begins.
    I did everything but the last step here (AECC14):
    10520_frozenparticlegalaxy.aep.zip
    Reading that again, you want to create the Milky Way, not a galaxy. The same principles apply: You can move the emitter across the sky, and change the shape while it is emitting to create the look you want.
    Senior Graphic Designer
  • Chris Gallego
    September 10, 2016 at 8:20 am
    Thank you very much Kalleheikki Kannisto
    Chris(tian)
