Activity Forums Apple Final Cut Pro Legacy Can I convert audio captured in 1 channel to 2 channels in the timeline with FCP HD 4.5?
  • Can I convert audio captured in 1 channel to 2 channels in the timeline with FCP HD 4.5?
    Posted by Luis Guerrero on June 15, 2005 at 9:30 pm
    I have several single person interiews recorded with a mono mic. I have captured the video into FCP HD. In order to get audio output from L & R speakers I have to pan the the audio track to the middle. Is this the only solution? Or should I get “Y” adapter to record the mono audio on both left and right channels.
    Thanks.
    Luis
    Matt Murray replied 21 years, 2 months ago 3 Members · 3 Replies
  • Matthew Brunn
    June 15, 2005 at 9:41 pm
    Doesn’t which you do, it will still be mono. Just twice as much of it.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.5
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Luis Guerrero
    June 15, 2005 at 10:32 pm
    The question I have is does it matter if I have audio only on 1 channel as long as I pan it to the middle so that it plays on left and right?
  • Matt Murray
    June 15, 2005 at 10:58 pm
    You can copy and paste a copy, then make them a stereo pair.
    Worked for me once.
    Matt Murray
    Lineside Productions
    Wellington, FL
    https://www.edgesportfishing.com
    Florida Sailfish videos, pictures and more
    Mac OS X 10.4.1 , QT 7.0 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD 5, DVDSP 4, Compressor 2.0, Motion 2.0
    Soundtrack Pro 1
