Activity Forums Audio Can I convert audio captured in 1 channel to 2 channels in the timeline with FCP HD 4.5?
  • Can I convert audio captured in 1 channel to 2 channels in the timeline with FCP HD 4.5?
    Posted by Luis Guerrero on June 15, 2005 at 9:33 pm
    I have several single person interiews recorded with a mono mic. I have captured the video into FCP HD. In order to get audio output from L & R speakers I have to pan the the audio track to the middle. Is this the only solution? Or should I get “Y” adapter to record the mono audio on both left and right channels.
    Thanks.
    Luis
    Luis Guerrero replied 21 years, 2 months ago 2 Members · 2 Replies
  • David Jones
    June 16, 2005 at 1:13 pm
    Your audio is a mono source, so when you capture select video + channel 1.
    Or since you have already captured the footage, just pan center as you did.
  • Luis Guerrero
    June 16, 2005 at 2:50 pm
    David,
    Thanks for you comment. I plan to do more single person interviews with a lavalier setup. I would like to know if the following order of operation is standard procedure for what I am doing.
    Equipment: Xl1s, wired lavalier,
    1. record audio on tape with wired lavalier
    2. capture into FCP with settings at video + Ch 1
    3. Pan captured audio to mid position between L & R
    I believe that I have attempted this before with the settings at video + ch1. The result was that I ended up with no sound on ch 2. In other words, when I dropped the clip into the timeline audio tracks 1&2 were part of the clip. Track 2 introduce noise. I understand that part of my problem getting to know the program better.
    Thanks to the Cow at least I can have a place to ask these basic questions.
    -Luis
