Activity Forums Adobe Premiere Pro Can I change the way the slip tool previews clips back to how it used to be?
  • Can I change the way the slip tool previews clips back to how it used to be?
    Posted by David Cabestany on August 31, 2015 at 5:05 pm
    Up to CC 2014 the slip tool would show the in and out of the clip I was slipping along with the prior and posterior clips, like the image below:
    On CC 2015 the new view/functionality looks like this:
    So it no longer has timecode, in and out points and it covers most of the clip I’m trying to see while I slip.
    I”m not an editor and I do not use Premiere as much as I use After Effects, but this seems cumbersome and a huge step back on an otherwise very useful tool.
    Is there a way to revert this to how it was before? some sort of legacy preference or something like that?
    D.
    David Cabestany replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
