Can I change the default setting for a FCP X filter?
I recently discovered the limiter filter courtesy of Larry Jordan. Woah! Awesome filter.
He has certain specs for the filter. I want to reset the default for the filter so that it accords with what he recommends. That said, i’ve been sleuthing online and can’t figure out how to change the default specs. is there a way to reset the default specs for a filter?
