Activity Forums VEGAS Pro Can I change one instance of a certain color in a video event?
  • Can I change one instance of a certain color in a video event?
    Posted by Raymond Pace on April 1, 2015 at 3:11 pm
    For example, pretend that this is an event on the Vegas timeline:
    If I wanted to take all the instances of the color blue that occur in this event, and change them to a different color (white in this case is what I need), could I do so? If so, how?
    Thanks.
    PS, please let me know if I didn’t explain clearly enough.
    Graham Bernard replied 11 years, 5 months ago 2 Members · 3 Replies
  • Graham Bernard
    April 1, 2015 at 5:28 pm
    I WAS going to suggest the 2nd Colour Corrector. But this way beyond that. You havoc a ton of different blues all over he place. If you’re running VP 12/13, yes, the FX could be masked to the areas you want, but even so….
    Grazie
  • Raymond Pace
    April 1, 2015 at 5:31 pm
    What if there was fewer blue in the video event? That was just an example? I should have used something closer to what I’m actually working on?
    Would you mind explaining what I would do with the Secondary Color Corrector?
  • Graham Bernard
    April 2, 2015 at 5:14 am
    [Raymond Pace] “Would you mind explaining what I would do with the Secondary Color Corrector?”
    Well, I did a Tutorial on how to do a 2-Colour on Black using the Secondary Colour Corrector. Here’s that from 6 years ago:-
    https://reels.creativecow.net/film/grazie-2colour-and-black-and-white-and-grey-background
    Would that help you? It may give you an idea . . . ?
    Grazie
