Activity Forums Adobe After Effects Can I change a NTSC template to PAL and resize?
  • Can I change a NTSC template to PAL and resize?
    Posted by John Doggett-williams on July 18, 2010 at 11:30 pm
    There’s an NTSC template I like but need to modify, I want to convert it from NTSC to PAL and also resize it from HD (1920 x 1080) to 1280 X 720. Is there a simple answer?
    Thanks in advance
    John doggett-williams
    John Doggett-williams replied 15 years, 10 months ago 2 Members · 4 Replies
  • Stephen Smith
    July 19, 2010 at 12:09 pm
    What program are you asking about? Motion?
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • John Doggett-williams
    July 19, 2010 at 10:59 pm
    Yes, Motion 4
  • Stephen Smith
    July 20, 2010 at 4:17 pm
    I find the easiest way to do it is, create the Motion project file that you want. Then open up the template. In Motion you can have more then one project open at a time. Make sure you have the project pane or timeline open on both. Move one over so you can see both at the same time and drag the contents of the Motion template into the project file you want. Motion will convert the frame rate for you. You will need to resize a little. I find it is easiest to get everything in one group and change the size of the one group. Hope this helps and best of luck.
    Stephen Smith
    July 21, 2010 at 2:29 am
    That’s great Stephen, I’ll let you know how I go
