Activity › Forums › Apple Final Cut Pro Legacy › Can I capture Sony V1E tapes using a Sony V1U???
  • Can I capture Sony V1E tapes using a Sony V1U???
    Posted by David Roth weiss on November 8, 2008 at 6:25 pm
    Cross-posted from the HDV Forum because no one answers questions over there.
    A cameraman in the land of PAL is shooting some material for me at 1080 50i using his Sony V1E (European PAL model), will I be able to capture from his tape using my Sony V1U (NTSC model). I understand that I will need to capture PAL, the question is can I do it?
    TIA,
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
    David Roth weiss replied 17 years, 10 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    November 8, 2008 at 7:57 pm
    Yes! No! I have no idea. I just htought I’d give you a response.
    My inclination is…maybe? Do you have a v1U? Can you put in 50Hz mode? If not, then no. If so, then yes!
    Jeremy
  • David Roth weiss
    November 8, 2008 at 8:06 pm
    Well, that certainly clarifies things… NOT!!!
    Anyone with a more definitive response?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    November 8, 2008 at 8:54 pm
  • Paul Dickin
    November 8, 2008 at 9:05 pm
    Hi
    To further not clarify things…
    I did this in the TRV-900 DV era, using iMovie, which didn’t used to be so fussy about the incoming FW signal.
    With an NTSC tape in a PAL TRV-900E camcorder, I first connected an NTSC mode Canopus ADVC box to the computer, and got iMovie up and ready for NTSC capture, then hot-switched the FW cable to the camcorder in Play mode. Whereupon iMovie happily captured the tape.
    Of course iMovie these days would use AIC for HDV ingest, and I don’t know if it remains as standards-unfussy as it used to be…
  • David Roth weiss
    November 8, 2008 at 9:09 pm
    Good find Jeremy!!! So, looks like I can just borrow/rent my cameraman’s Z1 and I’ll be all set.
    Okay, you’re back to your usual 5-Cow rating once again, for a few mins. you had dropped down temporarily to 4.8-Cows.
    THNX,
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
