Activity Forums Apple Final Cut Pro Legacy Can I capture HDV/24p footage from a JVCHD100 into FINAL CUT 5.1.4?
  • Can I capture HDV/24p footage from a JVCHD100 into FINAL CUT 5.1.4?
    Posted by Warner Brown on August 3, 2008 at 12:35 am
    Or do I absolutely need FCP 6? I have FCP 5.1.4 and seem to be unable to capture HDV footage via the DVCPROHD 720p/24 input as well as the apple intermediate codec.
    Warner Brown replied 18 years, 1 month ago 3 Members · 4 Replies
  • Shane Ross
    August 3, 2008 at 1:43 am
    That camera shoots HDV, not DVCPRO HD…so you cannot capture it as DVCPRO HD. Not without a capture card.
    Shane
  • Warner Brown
    August 3, 2008 at 2:06 am
    Thanks, I didn’t realize that..but the apple intermediate codec does support native HDV. Yet in “log and capture” it just says “preview disabled” I have imported DV footage in before, I’m not sure why I can’t import HDV, all my settings seem to be correct.
  • Adam Schmidt
    August 4, 2008 at 2:03 am
    You can capture HDV 720/24 via firewire using the ease setup under the file menu. Then transcode to any format you’d like via compressor or QTp.
  • Warner Brown
    August 6, 2008 at 7:59 am
    Thanks Adam, I overlooked that, now it works perfectly.
